Beogram 4000 power supply issue
ALF
AUS
Posts 1,015
Silver Member
ALF Posted: Fri, Jul 9 2021 5:46 AM
Hi All,
i ran into a faulty transistor on the power supply board: 2TR6 = BC119
can someone advise if a BC141 (similar type) would work as a replacement or if not,
is there a equivalent you can suggest ??
Thank you kindly
ALF
Mark
San Francisco
Posts 107
Mark replied on Fri, Jul 9 2021 6:13 AM
That is like to need circuit values adjusted. Take a look at this table of substitutes: https://alltransistors.com/crsearch.php?mat=Si&struct=NPN&pc=0.8&ucb=60&uce=30&ueb=5&ic=1&tj=200&ft=40&cc=25&hfe=40&caps=TO39
Mark
San Francisco
Posts 107
Duplicate - please remove.
Mark
San Francisco
Posts 107
ALF
AUS
Posts 1,015
Silver Member
ALF replied on Fri, Jul 9 2021 7:24 AM
Thank you - yes I have seen that table.
I was thinking of a BC 141-16 transistor  as a replacement for testing only until I get the BC119 transistors.
ALF
ALF
AUS
Posts 1,015
Silver Member
ALF replied on Sun, Jul 11 2021 9:55 AM
So far so good 👍😁
looks like the BC 141-16 transistor worked and after replacing one of the glass reed switches the  6V rail is back in business.
ALF
Page 1 of 1 (6 items) | RSS
