Beolab 18 indicator light
thorne
Posts 315
thorne Posted: Fri, Jul 9 2021 10:35 PM
Why does the light on my 18 stay solid green, with no sound?
Aussie Michael
Melbourne, AU
Posts 3,730
thorne:
Have you tried turning the power off, waiting a few minutes then turning back on?
I found this in the User Manual, but doesn’t state about a constant green light
10 Product status and wireless indicator:
– Red (solid): The indicator is solid red for some seconds when the speaker is connected to the mains, switches off, or when it restarts after it has been reset.
– Green (solid): The indicator is solid green for some seconds when the speaker switches on, then it dims.
– Green (flashing): A software update is in progress, during which the speaker cannot play. Do not disconnect from the mains.
– Green (flashing quickly): If you have a wireless transmitter in your setup, the speaker is in associate mode and ready to be connected to the wireless transmitter.
– Orange (solid): The signal strength for a wireless connection is low.
– Orange (flashing slowly): The product is overheated and will shut down temporarily.
– Orange (flashing quickly): An error has occurred. Disconnect the speaker from the mains and reconnect it again. If the problem persists, contact your Bang & Olufsen retailer.
Page 1 of 1 (2 items) | RSS
DigiCert Secured Site Seal
