I accidently shorted the speaker output wires on my Beomaster 1900. This killed all output from the left channel.
This post has 3 Replies | 0 Followers
quattttro
Posts 12
quattttro Posted: Mon, Jul 12 2021 1:32 PM
Right channel still works. What component (s) would most likely die in this scenario? Where would you check first?
I've checked the Darlingtons transistors with my component tester, and they seemed to check OK, and I notice nothing burned or blown caps. Checked various resistors in the left channel power amp circuit, all are fine.
Here she is, before the incident:
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Mon, Jul 12 2021 9:13 PM
Replace
IC200 (*)
IC201
TR216
TR217
TR214
TR215
TR213
TR212
Check all other components downstream from TR212, including R242 and R245.
Also replace the idle current trimmer, and readjust to the setting stated in the servicemanual.
Don't buy semiconductors from Asia. They will almost certainly be fakes.
*EDITED
quattttro
Posts 12
quattttro replied on Mon, Jul 12 2021 11:30 PM
Will do, thanks. Which one is IC100 (did you mean IC200?)?
Dillen
Posts 13,191
Dillen replied on Tue, Jul 13 2021 7:05 AM
quattttro:
Yes. Now corrected.
It's always a good idea to replace output stage transistors in pairs (or quads where applicable).
If one has shorted, the other one will have seen a hefty overload.
Page 1 of 1 (4 items) | RSS
