Beomaster 6500 inputs
mat-s
Posts 3
mat-s Posted: Thu, Jul 15 2021 7:43 PM
Hello,
I've had a Beogram 6500 deck for many many years which worked happily with a Sony amp. Said amp recently died so I decided to get the Beomaster 6500.
Phono connection is great.
When I connect additional non B/O equipment to the Beomaster, no matter what input I use, (and here I'm using Aux), if I select another input, say CD, or Tape, the sound comes out of there regardless.
This is very foxing! How might this be happening?
I only have a Beo4 remote to control the Beomaster. And if anyone knows how I might use this to tune the radio I'd be delighted to find out.
Many thanks!
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Thu, Jul 15 2021 8:52 PM
Most likely situation is, that your cable/adapter is sending signals in through the record signal pins instead of the playback pins.
mat-s
Posts 3
mat-s replied on Thu, Jul 15 2021 9:42 PM
Interesting, and thank you - I will investigate with some new cables!
mat-s
Posts 3
Page 1 of 1 (4 items) | RSS
