Beosound 9000 with Beovox 3000 (flat panel)
This post has 4 Replies | 0 Followers
Luket71
Posts 16
Silver Member
Luket71 Posted: Sun, Jul 18 2021 1:50 PM
Hi All
Was wondering if you could help?
I am trying to set up my Beosound 9000 mk2 with my Beovox 3000 (flat panel) speakers?
I have acquired a ml\mcl converter which i have been told should do the trick? however it is not working at the moment?
I have the Beosound 9000 connected to the ml converter by master link cable and then the speakers coming out of the converter with the standard b & o speaker cables?
Has anyone got this set up? or give me any advice?
Many thanks
Luke
Millemissen
Flensborg, Denmark
Posts 14,680
Hi Luke,
All you have to do, is to connect the converter AKA the Beolink Passive to the BS9000 with a fully wired Powerlink cable/MK2 - and then connect the speakers to the converter box using the normal speaker wires with a din plug., that you already have.
Of course the converter need electric power as well.
This way the converter acts as an amplifier for the Beovox.
Luket71
Posts 16
Silver Member
Luket71 replied on Sun, Jul 18 2021 3:48 PM
Hi MM
Does it have to be a MK2 cable? as I'm using an original master link cable???
Also there is a red light on top of the converter box, next to it is says OFF with a little push button? does this need an IR eye fitting to it???
Converter model is 1651
Many thanks
Luke
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Sun, Jul 18 2021 4:47 PM
Luket71:
Hi MM
Many thanks
Luke
use a PL cable as proposed by MM. Then the converter is used as amplifier for the BVox.
Note: don’t use the ML cable, no IR is needed.
Luket71
Posts 16
Silver Member
Luket71 replied on Sun, Jul 18 2021 5:20 PM
Great stuff
Ive just ordered a power link cable mk2
Thanks for your help Guys
Many thanks
Luke
Page 1 of 1 (5 items) | RSS
