I am sure some of you have noticed that the forum was down respectively you could not post in the last couple of days.
Thanks to the great and enduring work of Keith (Saunders) it seems to be fine now again.
To keep a forum like this sound and running is quite a job - therefore a big thank you to Keith and whoever was involved in fixing things.
Yes, great work whoever fixed it! I lost a couple of posts hence assume that it has been restored to an earlier time, but good to see it back up and running.
Thanks Keith et al
Thank you for your and others effort.
Thank you for your kind feedback, it was just me dealing with the problem!!!
Regards Keith....
