The unit turns on but stay only for less than a minute.
move switch to line and than back to speaker plays again for short time
any suggestion to where to look for this problem?
Is this both speakers? if it is only one, then try swapping them over to make sure the leads are ok. Sorry, not sure what else to try but someone else may have a better idea.
Joe
Andrew: Is this both speakers? if it is only one, then try swapping them over to make sure the leads are ok. Sorry, not sure what else to try but someone else may have a better idea.
Thanks Andrew. i will do the test today. in the meantime however I swap out the relay since i had bought two replaced only one on one speaker almost 10 years ago.
Which did something but not what i hoped for. The speaker turns on and is humming only.
