Moment + MinimServer - What's is the Best Server Settings?
This post has 29 Replies | 0 Followers
kimhav
Malmo, Sweden
Posts 314
kimhav Posted: Wed, Aug 4 2021 9:55 AM
Aware that there are several other threads that talks about MinimServer tweaks to a certain extend and of course there is MinimServers forum as well together with the online documentation, but looking now to switch from Twonky to MinimServers and would like to pick the community's collective brains for the best MinimServer settings when used together with Beosound Moment.
Of course there are also some small tweaking to be made on the Moment, thought limited, and the important one would be the switching to Expert mode. This made my Moment far more stable based on that it's not constant scanning for new DLNA data. After that I noticed that my Twonky after couple of month falls to sleep, well more coma, it's not responding which I then notice on the Moment :-) Hence why I'm looking at MinimServer.
Been toying around with a MinimServer Ubuntu Docker installation which works out fine and some tweaks seems to work fine. Also, recall that Moment is fairly limited to what it picks up from the DLNA tags based on the audio files (mp3/FLAC) and some of the nice tweaks that MinimServer has in the documentation doesn't really fly with Moment.
Also, based on the current MinimServer v2.x, did anyone manage to get the Artist image to work out or is this still only working with Twonky using 'beoartists' folder. Was this ever picked up and can be used with MinimServer or are there other tricks?
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Wed, Aug 4 2021 7:22 PM
kimhav:
True, the tweaks in Minimserver set, are maily for the other DLNA renderers and controllers (such as the Beoliving app). The Moment does not pick up the other tweaks which present ones collection better and make accessing artists, albums, tracks easier.
Still the Moment works fine with Minimserver.
But some tweaks done also works fine for the Moment. For example I did set the transcode option to convert DSF files to WAV24;96 (24bit; 96kHz). Then I can play SACD ripped files directly to the Moment.
kimhav:
In principle I think this should work. Have to look into it though. Note: the artists show up nicely in the Beoliving app with Minimserver.
I used a trick to get the artists visible in the Moment. But that has nothing to do with Minimserver.
kimhav
Malmo, Sweden
Posts 314
kimhav replied on Thu, Aug 5 2021 7:32 PM
Carolpa:
If you converted the DSF 5.1 audio files to WAV 2.0 why didn't you opt for FLAC 2.0 - Any particular reason?
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Fri, Aug 6 2021 6:03 AM
kimhav:
actually, if possible I ripped SACD as well in 2.0 as 5.1.
So the Moment is only fed with DSF 2.0.
Flac would also be possible, but why 2 “conversions”.
Note: I rip if possible to a native formats. For example I’m used to rip CD’s to WAV files.
kimhav
Malmo, Sweden
Posts 314
kimhav replied on Sat, Aug 7 2021 11:17 AM
Don't need to be any additional conversions steps, for example dBpoweramp, would support direct conversion of SACD to FLAC. Hence why I was wondering :-)
Circling back to MinimServer, which works absolutely fine with Moment as indicated and suggested in lots of other threads in this forum. About the BEOARTISTS folder which is setup in Twonky through the Photo Album which I realise that MinimServer doesn't support and would needed to be implemented which I doubt would happen. Then again, is this something that has been raised as a possible workaround with Simon Nash as plugin/addon to MinimServer?
kimhav
Malmo, Sweden
Posts 314
kimhav replied on Sat, Aug 7 2021 12:01 PM
Additional question about the Moment then together with MinimServer; does it still make sense to enable Export Mode?
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Sat, Aug 7 2021 3:09 PM
kimhav:
See
The Artist pictures are added to Minimserver and are shown in the Beoliving app.
For the moment  they will not be show in the Moment, because they are not in the right Moment Expert-Mode directory. I never figured it out ........ nor tested it. But you made me curious if it is possible.
kimhav
Malmo, Sweden
Posts 314
kimhav replied on Sat, Aug 7 2021 6:41 PM
Carolpa:
For the moment  they will not be show in the Moment, because they are not in the right Moment Export-Mode directory. I never figured it out ........ nor tested it. But you made me curious if it is possible.
Only using the Bang & Olufsen android app on my side, but the Khimo BeoLiving looks nice. But, about the Twonky Photo hack won't work since MinimServer doesn't support photo handling. But, if MinimServer would support that the folder, indexArtwork, would be possible to be deployed as beoartists including as dlna media; well then it would work else not.
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Sun, Aug 8 2021 4:46 AM
kimhav:
You can rename the indexArtwork folder to BEOARTISTS with artworkFolder command.
Minimserver scans and work fine/correct with this directory name. But the Moment doesn't pick up the Artists yet.
The question is: does the Moment use a dedicated directory for the Artist photo's or does it pick up the info from the scanned/indexed DLNA server?
maybe Lyle Clacke can comment: how are the Artist pictures selected in Expert Mode?
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Sun, Aug 8 2021 8:34 AM
Carolpa:
The Moment relies on a DLNA photo service that Minimserver does not offer, as simple as that.
I suggested to Lyle to allow choosing another DLNA server for photo instead of defaulting to the same than for the Music, but unfortunately we all know what happened to Moment development.
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Sun, Aug 8 2021 8:46 AM
mbolo01:
Minimserver 2 has the option for showing Artists pictures (see the picture before! Beoliving shows the Artist pictures processed by Minimserver).
So NOT simple as that!
see below another picture now of the B&o app (pictures are coming from Minimserver)
Note: these pictures I added myself to Minimserver!
Some additional remarks:
1. I used for a long time another workaround to show the Artist Pictures on the Moment. It works perfectly.
2. In the end, it is not a big issue to me! Maybe even no issue.
3. But still it would be interesting to find out if it could work (maybe it will, maybe it won't).
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Sun, Aug 8 2021 8:58 AM
Yes it is a simple as that.
Moment is simply looking a BEOARTISTS folder from the root of the DLNA Photo server and image files inside must exactly match the album artist name metadata in order to use the image in the artist’s tile.
As a Moment software beta user, i have had many interaction with B&O on this front.
Even if Minimserver can expose the artist image, the Moment logic simply does not make use of it, like it is ignoring other useful metadata.
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Sun, Aug 8 2021 9:08 AM
mbolo01:
You weren't the only one!
mbolo01:
Fine retelling me, but your explanation just opens an opportunity.
What if there is a way to trick the system in a way that the Moment looks in the right directory and Minimserver scans these picture also.
Maybe simple as that! That's what I'm searching for.
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Sun, Aug 8 2021 9:18 AM
Carolpa:
As a former beta user you should then understand that the Moment does not browse a file system directories but a DLNA Photo server directory of the SAME DLNA server servicing the music.
Unless Minimserver introduce a photo service (as suggested in this thread), I don’t really see what else you can trick, particularly on the Moment side.
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Sun, Aug 8 2021 9:44 AM
mbolo01:
Dutch sayings:
"Can't" lies on the graveyard and "Won't" lies next to him.
That is what I'm reading in your posts. Where is your positive attitude to reach, search, solve questions like these.
Maybe we solve it together, maybe not........... but not see NEW opportunities and examen them .............
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Sun, Aug 8 2021 10:57 AM
Carolpa:
Maybe you should also read « pragmatism » in my posts ?
I’m a simple product end user with decent tech background, I don’t have the control of the Moment code, nor the Minimserver one, and my analysis conclusion is that there is nothing people like me can do to make the Moment think the Minimserver DLNA music server is also a photo DLNA server with a BEOARTISTS directory full of artists’ images, i guess you can understand that don’t you?
If I was a talented dev, I would write a multi platform proxy DLNA server to direct music and photo requests to appropriate DLNA servers, maybe it exists somewhere, I didn’t search and I also don’t want to invest more time in a divest product like the Moment which may also soon loose its Deezer compatibility (IFTTT is dropping Deezer as Deezer no longer publish its API which is maybe the sign of a coming change that will force third party vendor to adapt their code …. guess what for the Moment)
That said, I fully support your effort.
kimhav
Malmo, Sweden
Posts 314
kimhav replied on Sun, Aug 8 2021 3:36 PM
While I'm not a developer, but one might say that some of the tweaks that Moment customers are looking for shouldn't be that much of an efforts, if the dev team is still around. Another option which is far fetched would be to ask B&O to make either the full software or partial software open source which would allow for tweaks. Of course I can't see this happen, but who knows they've kind of tried a few hardware projects such as the HiFiBerry were they dipped their toes into the sharing and developing something for the community.
About the Moment, is there a Moment 2021 thread and is it worth trying to compile a priorities list of update request to be shared from multiply customers.Who knows, they might cave in (can always wish).
Going back to the MinimServer, it's up and running and doing so fine and I can live without the Artist images which was kind of nice and I just need to use the Bang Olufsen app a bit more which I very rarely use.
Question then again about the Moment Expert Mode; does it make sense to enable this for MinimServer?
kimhav
Malmo, Sweden
Posts 314
kimhav replied on Sun, Aug 8 2021 4:49 PM
Carolpa:
Looks much better with the customized icons compared with the stock icons that Bang Olufsen app shows by default which looks quite boring. So thanks for this showcase of the BnO app.
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Sun, Aug 8 2021 6:09 PM
kimhav:
I used to leverage the Expert Mode to (1) get the control over Moment database refresh and to avoid continuous scanning of my music library (55 k tracks) triggered by Twonky default playlists updates (last played and most played) and (2) to manage my own artists images.
Minimserver does not have such playlists that gets updated each time you play, so without Expert Mode turned on, Moment updates would occur automatically only when your music library content changes (add/remove/change), unless Minimserver sends state changes when music is played, I haven’t tested it in depth on this front.
kimhav
Malmo, Sweden
Posts 314
kimhav replied on Mon, Aug 9 2021 8:55 AM
Thanks for confirming with regards to Expert Mode and MinimServer. Twonky constantly updating the playlists quickly killed the Moment so that was the only option to get it to work stable.
And to summarize the all the tweaking that can be done with MinimServer won't affect the Moment unit but will have an impact, for the better, on the BeoLiving and Bang Olufsen app.
The follow-up question is of course what config/settings are you using with MinimServer v2`? Since I'm still exploring the wealth of parameters and tweaks available for MinimServer this is what I'm currently running with:
indexTags = Albumartist, Artist, Date, Genre, All Artists, Composer
serverOptions = indexArtwork=folder
Added the Albumartist to have the index sort by Albumartist instead of Artist tag and then of course the indexArtwork tag which we already discussed in the thread.
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Mon, Aug 9 2021 4:37 PM
Minimserver is running with these settings:
alphaGroup = All=100
contentDir = {F:\Photo}{F:\Stereo}
displayName = BeoServer
indexTags = AlbumArtist, All Artists, #Audioformat:Format, #AudioChannels:#Channels, #AudioQuality:Quality
itemTags = Tracknumber
.logLevel = info
mergeFolderAlbums = true
serverOptions = indexArtwork=all, artworkFolder=BEOARTISTS
stream.options = convOut=-af volume=+3dB
stream.transcode = dsf:wav24;96, flac(88):wav24;96, wav(88):wav24;96, wav(>96):wav24;96, flac(>96):wav24;96
tagFormat = Artist.displayFormat={$Artist}, Title.displayFormat={$Tracknumber^^. ^$Title^^}, AlbumArtist.displayFormat={$AlbumArtist}
tagOptions = items.sortTags={#AudioChannels, Album, tracknumber}
This is the setting used for the Minimserver set for the Moment and Beosound 5 Encore (of course also accessable to other NL devices)
Another second Minimserver is running with "wider" specs (surround files for example, etc.)
See the differences:
1. indexTags: All Artists  -> if only Albumartist is in the tag, it will also show for "Artist"
2. indexArtwork: set to all -> in a dedicated folder the artwork is searched, if not present the artwork from an album is shown
3. tagFormat: Title.displayFormat -> this way the server will show the <tracknumber>. <title>. It uses the tracknummer and title stored in the tags
Example: "01. Shine on you crazy diamond"  is shown by the player/renderer
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Mon, Aug 9 2021 5:00 PM
@Mbolo01
Thumbs Up
mbolo01:
I can't get the artists visible in the Moment. It seem I did forget a step but I don't know which one......... or what I'm doing wrong?
1. using Twonky
2. Set directory /Photo with all Artists pictures. Within is a subdirectory named "BEOARTISTS".
3. this /Photo directory is set-up as Photo's only
4. Name of picture file is identical to Name in music file tag
5. Twonky set as DLNA server on Moment; Moment set to Expert mode; rebuild the db.
No pictures shown? What did I forget since the last use of the Expert mode?
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Mon, Aug 9 2021 5:21 PM
kimhav:
This option is also excellent (but not available on the Moment):
see for example "Abbey Road"
There are two entries; one are all stereo albums, the other are multichannel versions of Abbey road.
Selecting the Stereo versions of Abbey Road; one can select the original USB version of 2009, the new 24bit-96kHz of 2018 and the Sessions CD's of the Extension Edition. If you give the command play in this screen, all the three choices will be played in succession.
but you can choose one of the three; below the 24bit-96kHz version is chosen.
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Mon, Aug 9 2021 7:38 PM
Carolpa:
If I’m reading you well, you misplaced the pictures. Artists pictures must be moved in the BEOARTISTS directory
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Tue, Aug 10 2021 5:06 AM
mbolo01:
If I’m reading you well, you misplaced the pictures. Artists pictures must be moved in the BEOARTISTS directory BS Moment, BS Core, BG 4002, BC 4500, BS1, BL18, BL19, BL8000 + RCV1, A6, M5, M3, A1, P6 (tks Botty), H5, TR1
I didn’t wrote it how it actually is.
The /photo is the picture directory which is scanned by Twonky. Within this directory you find the BEOARTISTS directory. This directory contains the Artists pictures.
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Tue, Aug 10 2021 8:37 AM
Carolpa:
Then I don't see any issue in your settings. I just did a reset on mine to confirm these settings and I can see the pictures properly associated to the artist tiles (I have a test library with a few albums).
If your library is large, from memory, it can take some time after a rebuild to display the picture.
I trust you have done all the possible controls, but here are the ones I'm thinking about: Control that you can properly see the artists pictures exposed by Twonky from the Twonky UI or any other DLNA photo renderer Look for any error message in the Moment notifications Make sure picture name perfectly match artist name as exposed by the Moment, names are case sensitive Check that there is no trailing blank character in BEOARTISTS folder name (depending on the O/S used)
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Tue, Aug 10 2021 5:33 PM
mbolo01:
Carolpa:
Thx
I will recheck my settings. I will make a test environnement with a few artists and albums.
Note: Minimserver uses/scans the same pictures and compares it with the same music tags. There all works fine.
addition: what file type and file size do you use?
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Tue, Aug 10 2021 7:22 PM
Carolpa:
JPEG files and size is usually small, average 200KB.
Image size is a very good point, didn't think about that. I usually resize my album covers to be under 1MB as I think I remember having issues with the Moment when they were larger, so I would not be surprised that a large artist image fails to be processed by the Moment, I'll give a try.
EDIT: I added an album of a new artist with image size = 3.2 MB, there was no issue adding it
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Sat, Aug 14 2021 2:43 PM
mbolo01:
Carolpa:
my Moment keeps refusing to display the Artists,....grrr
Do you use the latest Twonky Server? At "mediareceivers" how are the settings for your Moment? thx in advance
note: duration of approval of thiz post 1 week.
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Wed, Sep 1 2021 10:29 AM
Carolpa:
I really don't understand why .... Mystery of the Moment.
I'm using Twonky Server 8.5.2 on a QNAP NAS.
The media receiver setting for the Moment is automatic and set to Generic Media Receiver / Advanced Media Navigation
Page 1 of 1 (30 items) | RSS
DigiCert Secured Site Seal
