Beolab 5000 (60:th), 2N3055 in the power supply breaks when speaker is connected
This post has 30 Replies | 1 Follower
Gunnar Faith-Ell
Sweden
Posts 23
Gunnar Faith-Ell Posted: Wed, Aug 11 2021 9:39 AM
I am repairing a Belab 5000. All capacitors have been changed. The Power supply is repaired with new transistors, new 18V zenner and show correct values (60V, over the 33V Zenner diode about 34V).
The problem is when I connect a load, a pair of speakers (RL150 or others) then at power on it's a "pop" sound in the speakers and the two 2N3055 transistors in the power supply breaks emediatly. The voltage then raise to about 76V (short circuit in the 2N3055). The fault occure indipendent of volume.
The amplifier works, I have checked it whith tone generator and osciliscope. It also works when the power supply gives 76V with the speakers. I checked the 2N3055 in the amplifier with a Huntron Tracker (desoldered).
Some earlier repair has been done on this unit, one of the 38647 in the amplifier has been replaced with another transistor type.
Any good ideas on where to start?
My thoughts are:
1) Problem with the batch of 2N3055? I have checked the 0.22ohm in serie with the transistors.
2) Problem with the current reduction through the 0.22ohm in the power supply, maybe change the resistor to a higher value?
3) Problem with the 3000uF caps to the speakers? They have been changed by someone earlier to correct value but much smaller type. (They measure ok).
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Wed, Aug 11 2021 12:07 PM
1. Most likely
2. The emitter resistors are not for current reduction.
3. Not likely if they measure fine.
Where did you buy the 2N3055?
And can we see how they look?
Gunnar Faith-Ell
Sweden
Posts 23
Thank you Martin for a fast reply.
1) The 2N3055 come from a workshop that I bought so its not possible to trace the actual source. What do you recommend for make of them to be sure its original? Here is a picture of them:
2) No it's not the emitter resistors, there is one more in the power supply with the same value as the emitter resistors. According to the service manual it should reduce the current at 7A. My idea was to change it temporary for fault finding. But first option is to check the 2N3055 and maybe order new ones.
Gunnar
Gunnar Faith-Ell
Sweden
Posts 23
Gunnar
Dillen
Posts 13,191
Dillen replied on Thu, Aug 12 2021 9:30 PM
That transistor is a counterfeit/fake.
See this:
playing with bits: Counterfeit 2N3055 Transistors from eBay (bradthx.blogspot.com)
Can you wipe off the lettering with IPA and a cotton bud?
Gunnar Faith-Ell
Sweden
Posts 23
ok, I will order new transistors.
Thank you
Gunnar
Dillen
Posts 13,191
Dillen replied on Fri, Aug 13 2021 5:55 PM
Perhaps it would be a good idea to show them to us before ordering.
Or find NOS or even good used ones.
chartz
Burgundy, France
Posts 4,171
chartz replied on Sat, Aug 14 2021 9:27 AM
I hadn’t seen this thread.
Yes, as Martin says, definitely counterfeit or fake 3055’s. You would be surprised if you opened one Stick out tongue
Even real noughties ones tend to pose problems on devices that used the original RCA ones.
The best bet is to buy untouched old 60’s and 70’s amps that used RCA or Motorola ones. They are aplenty and usually very, very cheap.
Jacques
Gunnar Faith-Ell
Sweden
Posts 23
Ok, I will see what I can find.
Gunnar
hemenex
Posts 569
hemenex replied on Mon, Aug 16 2021 10:33 AM
I just wanted to add that not all of  ST's 2N3055's are counterfeits.
I did order a bunch of them from a distributor back in 2013 when I heard about ST givin' up the production.
After reading here I tried to rub-off the printing with alcohol; it faded somewhat but was not erasable. See lthe left front transistor
And I notice a bit more "digital" print font on the transistor compared to the other picture in this thread.
Does anyone have a description of the printing on it? I searched the net and my datasheet collection but couldn'd find a valid one for the 3055 (Martin?). I think these are 2013 Week 24 and from Malaysia.
Haven't used one of them yet but this one being in a lot of electronics from times gone (power supplies, amplifiers...) I decided to get enough for the rest of my electronic life :-)
I'm hoping that they weren't counterfeits already in 2013 ;-)
  hx
chartz
Burgundy, France
Posts 4,171
chartz replied on Mon, Aug 16 2021 3:32 PM
I’m certain those are genuine, unlike the joke above ☺️
Jacques
Dillen
Posts 13,191
Dillen replied on Mon, Aug 16 2021 3:41 PM
I agree, but polystyrene is not exactly ESD-safe, and it even caries a warning label Geeked...
hemenex
Posts 569
hemenex replied on Tue, Aug 17 2021 8:52 AM
It's the original packaging box from ST Confused
And it's really non-conductive - I measured Sad
strange...
chartz
Burgundy, France
Posts 4,171
chartz replied on Tue, Aug 17 2021 9:16 AM
Dillen:
Well at least they aren’t MOSFETS Big Smile
Jacques
Gunnar Faith-Ell
Sweden
Posts 23
When trying to find a larger lot than 1-2 of them most looks like the fake one.
Perhaps it's easier to find a good replacement for 2n3055 which they dont copy?
chartz
Burgundy, France
Posts 4,171
chartz replied on Tue, Aug 17 2021 8:50 PM
Just stick to 3055’s. The whole amplifier is built around them, like the Quad 303.
Jacques
chartz
Burgundy, France
Posts 4,171
chartz replied on Thu, Aug 19 2021 11:08 AM
No. Avoid those undocumented things at all cost.
Those look good:
Used 3055 eBay
Jacques
Gunnar Faith-Ell
Sweden
Posts 23
I need more like 50 pcs...
chartz
Burgundy, France
Posts 4,171
chartz replied on Thu, Aug 19 2021 11:54 AM
For the Beolab? Confused
Jacques
Dillen
Posts 13,191
Dillen replied on Thu, Aug 19 2021 5:01 PM
I agree, the ones Jacques links to look fine.
If you need 50 transistors you could probably buy 25 pairs, -
but it's in the UK so customs and import duties/VAT will have you for dinner.
My advice would be to keep an eye on Ebay etc. and grab good lots of original RCA or Motorola.
Gunnar Faith-Ell
Sweden
Posts 23
I ordered the 2N3055 from CPC in UK and I will open one when they arrive and let you know if they can be trusted as a replacement. Otherwise I will send them back Big Smile
chartz
Burgundy, France
Posts 4,171
chartz replied on Fri, Aug 20 2021 3:17 PM
I bet they won't do in the Beolab 5000. I hope to be wrong.
Jacques
ablaumeise
Posts 54
When I come across a blown 2N3055, I usually replace it with a KD503 (essentially the eastern bloc variant of the 2N3055). Haven't had any issues so far.
You can easily find surplus from the 80s in big quantities, and they aren't expensive. And, the most important thing: nobody has started counterfeiting these yet ;)
Gunnar Faith-Ell
Sweden
Posts 23
So, I got the new 2N3055.. The one to the right.
Gunnar Faith-Ell
Sweden
Posts 23
The new one is 11gr and the fake 9 gr.
Gunnar Faith-Ell
Sweden
Posts 23
Now an inside picture from the new and from the fake 2N3055
Gunnar Faith-Ell
Sweden
Posts 23
Gunnar Faith-Ell
Sweden
Posts 23
And finally the Beolab 5000 is producing 60V and fully working. So the problem was the fake transistors.
chartz
Burgundy, France
Posts 4,171
chartz replied on Thu, Sep 9 2021 7:53 PM
Thanks for the update!
Jacques
Page 1 of 1 (31 items) | RSS
