Beogram CD 3500 - reading problem
This post has 7 Replies | 0 Followers
Jareen
POLAND
Posts 5
Jareen Posted: Sun, Aug 15 2021 12:26 AM
Hello,
it is my first post on this forum and i'd like to say hi to everyone. My experience with BO started many years ago and my collection of vitage models is still growing.
One of my CD players - Beogram CD3500 - has stopped working properly. The disc is detected and starts spinning but after 2-3 secs player returns to standby.
What i have checked so far:
- C2103 replaved with proper axial Philips (47 uF instead of 33uF)
- other capacitors checked with the tester are okay,
- all power supplies on servo PCB are correct,
- servo PCB checked for dry joints,
The player turned into service mode passes first 3 steps (i.e. 1. laser arm moves correctly, 2. laser sees the disc and catches focus, 3. spindle motor works) but the problem is in stage 4 - CD stops and sometimes starts to rotate backwards for 2 secs ("4" on display remains blinking, what is assumed by service manual as the probem with radial servo).
What can be the cause for such behaviour? I've changed TCA0372 as the final focus motor amplifier / radial amplifier but with no success. The only part that remained untouched and now gains my suspicion is TDA5709...
Have somebody met with similar case and would be so kind to shed some light on what to do?
Noah
San Francisco
Posts 71
Noah replied on Sun, Aug 15 2021 7:02 AM
I would try the TDA5709. Especially because it deals with Radial Signal Errors.
-Noah M.
RL 60.2, Beogram 5500, Beomaster 5500, Master Control Pannel 5500, Audio Terminal Remote, H9i, Beovox s45.2, Beosystem 2500 , Beogram 1602, Beolink 1000 remote, Beosound 2000, Beoremote 4.
Looking for: Beocenter 8000
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Sun, Aug 15 2021 9:09 AM
Clean the laser lens. (Always first thing to try, I suppose you already did that).
Check for ripple on the supply voltages. Check for cracked solder joints at the voltage regulators etc.
Jareen
POLAND
Posts 5
Jareen replied on Mon, Aug 16 2021 1:22 PM
Thank you for your quick replies. Of course all the optics has beed cleaned, even substituted by other working CDM 4 with no results. Everything seems to point at TDA5709. Full of worry I'am looking around the chip at reasonable price and quality. Of course not from aliexpress... I've found one used within easy reach, I hope still working. We will see.
Jareen
POLAND
Posts 5
Jareen
POLAND
Posts 5
Jareen replied on Sat, Aug 21 2021 6:46 AM
I've replaced TDA5709 - no success. I am running out of ideas what is going on
Pindsen
Denmark
Posts 49
Pindsen replied on Sun, Aug 22 2021 6:38 PM
You mention that supply voltages are OK but what about ripple as Dillen are proposing?
Have you tried to switch the Decoder board to see if that influences on the fault?
/Pindsen
Jareen
POLAND
Posts 5
Jareen replied on Tue, Oct 26 2021 1:15 PM
Sorry about the delay, but I've just figured out what caused such behavior - a brushless spindle motor. A lower bearing is glued into its assembly with a kind of red laquer. Small flake of this mass moved under the axis and hampered it. Just after servicing this point, the player passed all 4 steps of laser alignment and works fine, nevertheless many of my CD-Rs still are not accepted by it. There is no relation with the laser diode -it is such fussy on 3 laser units tested so far.
Apparently I've managed to save this player from the darkness. I wish one day it could be the same luck with my Beomaster 3500, where fault in +5V power supply propably burnt all the logic board.
Page 1 of 1 (8 items) | RSS
