Beocord 8002 stays in standby
This post has 7 Replies | 0 Followers
calman50
Posts 16
calman50 Posted: Tue, Aug 17 2021 5:02 PM
This beocord won't turn on and stays in standby mode. The PS is working and I have not found any out of spec voltages . Is this IC failure or could it be the switches ? Thanks
Noah
San Francisco
Posts 71
Noah replied on Tue, Aug 17 2021 5:15 PM
Hello. Are you sure the units getting power? If so then I will update this
-Noah
-Noah M.
RL 60.2, Beogram 5500, Beomaster 5500, Master Control Pannel 5500, Audio Terminal Remote, H9i, Beovox s45.2, Beosystem 2500 , Beogram 1602, Beolink 1000 remote, Beosound 2000, Beoremote 4.
Looking for: Beocenter 8000
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Tue, Aug 17 2021 5:21 PM
Keyboard connected?
Some decks have a fuse under the keyboard. Have you checked?
Does it go into standby when you connect mains?
calman50
Posts 16
calman50 replied on Tue, Aug 17 2021 6:52 PM
Yes its always in stand by . I have to remove #1 board to get to the key board #7 right? I recapped one these 10 years ago I forgot  how I got how to get  board #1 out . Working on it
calman50
Posts 16
calman50 replied on Wed, Aug 18 2021 1:04 AM
I'm getting  4.8v on either side of the fuse to ground . Its on Board #1
calman50
Posts 16
calman50 replied on Thu, Aug 26 2021 1:49 PM
I seem to have all voltages  but unit still won't turn on. I was able to source IC 7 &8 (board 1). I replace IC 8 with no change. I'm waiting IC 7. Can some explain to me how the unit turns on when the mains is plug in ? and any reasons why it won't turn on when plug in . thanks
calman50
Posts 16
I replaced IC 8 and the unit turned on and cassette motor is running. I have UUUU error message on the display, key pad doesn't work nor does record open, mem+ ,record lights. I can manually engage  the tape heads and there is a motoring boating sound in left the rights play but weak. So the short answer is bad IC. My question is would problems in the audio amp cause these problems , namely the error message and unresponsive key pad? IC7 and IC9 appear to be good. thanks
calman50
Posts 16
the motor boating sound in the left channel is the cassette motor.
Page 1 of 1 (8 items) | RSS
