New software Essence, Beosound etc
This post has 6 Replies | 0 Followers
stampfki
Posts 138
stampfki Posted: Sat, Aug 21 2021 9:58 AM
Hello,
there is a new version out there, 1.26
Any changelog and experience available?
Aussie Michael
Melbourne, AU
Posts 3,730
The last B&O app update version 3.16.1 has ‘better re-setup experience support for BeoPlay EQ. Improved Bluetooth stability. Fixed IOS 10 cras and minor visual glitches”
Is this the one you mean?
stampfki
Posts 138
stampfki replied on Sat, Aug 21 2021 2:09 PM
Thanks. But I’m referring to the device firmware.
moxxey
South West, UK
Posts 5,359
moxxey replied on Sat, Aug 21 2021 2:38 PM
stampfki:
The "software" is embedded in the firmware. ie. long gone are the days where only a B&O installer could update your firmware using his laptop (and it often went wrong).
stampfki
Posts 138
stampfki replied on Sat, Aug 21 2021 2:48 PM
Ah ok, I have seen it only in BeoTool. But the software is no update available yet.
Stan
Chicago-area USA
Posts 869
Stan replied on Sat, Aug 21 2021 3:09 PM
My BS1, BS2 and M3 have updated. My Essences have not.  Can't find any description of the changes.
trackbeo
Posts 644
trackbeo replied on Sat, Aug 21 2021 4:59 PM
Beosound 1 2nd-gen update from 1.10.xxxxx to 1.11.xxxxx.  "Software update failed" on mine, no reason or code# displayed.  So I rebooted it before trying again.  (Should have done that the first time, prophylaxis.:-)  Downloaded 100%, restarting product took 5 minutes; so don't fret.
N.B. Does not fix the bug where DLNA playback fails to update time counter to app & product sleep resets to start of track instead of pause point. (That zero sure gets passed around -- fortunately not to playback sound, which proceeds apace.)  So my other one will remain on 1.7.xxxxx.
Page 1 of 1 (7 items) | RSS
DigiCert Secured Site Seal
