Beogram 4000 set down point
This post has 3 Replies | 0 Followers
Beogramcollector
Posts 32
Beogramcollector Posted: Thu, Aug 26 2021 2:44 PM
Hi Beogram experts, posted this in the general forum, so it may have got lost as I didn't have any responses.
My BG4000 sets down far too early. As soon as the sensor reaches the platter, the tonearm lowers - i.e approx 1" before the actual start of the record. It happens irrespective of whether there's a record on, platter only etc etc.
Is this likely to be mechanical or electrical ? Hopefully someone can give me a few pointers on where to start looking.
Many thanks !
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Thu, Aug 26 2021 3:30 PM
Most likely to be an incorrect adjustment of the setdown switch.
Beogramcollector
Posts 32
Thanks Martin - I take it that's one of the slide contact springs ? Not sure which one it is, but will ensure all are the correct distance accord to the service manual.
Really appreciate the swift response !
Beogramcollector
Posts 32
Sorted it with a quick email from Rudy. He said to check the singles switch, so I cleaned all the contacts again with some 2500 wet & dry and everything works perfectly !
Page 1 of 1 (4 items) | RSS
