TiVo codes and beo6
This post has 4 Replies | 2 Followers
adlcorbett
Posts 12
adlcorbett Posted: Tue, Feb 19 2013 10:28 PM
Would like to be able to use Beo6 to control virgin TiVo box through Beovision 8.
is this possible? B&O stores are hopeless and so too is my local installer.
Anyone know and can recommend an installer to do in SW18?
adlcorbett@gmail.com
Simbohm
Posts 14
Simbohm replied on Wed, Feb 20 2013 2:45 AM
I am supposed to have this setup next month. I'll try and dig this post up if I remember.
A
stefan
200 miles from Struer
Posts 2,920
stefan replied on Wed, Feb 20 2013 11:59 AM
adlcorbett:
Why????
Tivo is on the PUC list. There is a puc called "G-Tivo".
It`s also in the new Beo6 CT 6.00.
Also mentioned in the old forum years ago...
Doesn`t it work?
Stefan
adlcorbett
Posts 12
adlcorbett replied on Thu, Feb 21 2013 10:54 AM
Neither installer nor store could give me a straight 'yes it's possible, this is how to do it.' answer.
I have no idea how to operate the config tool. I am no good with tech.
Pretty simple.
stefan
Posts 2,920
stefan replied on Thu, Feb 21 2013 11:15 AM
Yes - pretty simple.
But what I mean is that your dealer/installer/store should know about the Tivo PUC. They just  have to look into the config tool.
That`s what I have done....
And there should be a PUC for the Tivo if It`s in the Beo6 CT list.
You will find more information on this site ( If the PUC is not working you can also use a Lintronic box):
http://archivedarchivedforum2.beoworld.org/forums/p/37088/307918.aspx#307918
Stefan
Page 1 of 1 (5 items) | RSS
DigiCert Secured Site Seal
