A stater beogram
This post has 12 Replies | 0 Followers
MrLythgoe
Posts 7
MrLythgoe Posted: Mon, Aug 30 2021 8:26 PM
Hello
I have decided I should upgrade my turntable, seen as have fallen in love with Bang and Olufsen I would like an old beogram.
My dream turntable is a Beogram 4000 however currently they are out of my league.
Can someone please suggest a good starter turntable for me.
Any help would be appreciated
Thank you
Mark
San Francisco
Posts 107
Mark replied on Tue, Aug 31 2021 6:32 PM
To give you a recommendation, I would need additional information.
1. What is your comfortable price range?
2. Are you looking for one that needs no refurbishment or can you DIY?
3. You mentioned the 4000; how important is linear tracking?
4. Realizing that B&O no longer makes cartridges but Soundsmith does, which model(s) would you be looking at?
MrLythgoe
Posts 7
MrLythgoe replied on Tue, Aug 31 2021 9:38 PM
Hello mark thank you for the reply.
Anything under £500.
Sort off-I would only do it for a Beogram 4000-this an idea I do love as I’d get my dream and I would be very determined to learn and study about the turntable mechanically.
Not at all-I love the 4000 due to its sound,looks and quality.
I’d just get what I can afford and what fits-please do be aware the cartridge cost isn’t included in the £500.
Many thanks Jack
Mark
San Francisco
Posts 107
Mark replied on Tue, Aug 31 2021 10:40 PM
Based upon your responses I believe a Beogram 4004 would be within your budget. I picked one up with an MMC20EN cartridge that needed a bit of TLC recently for $450 on eBay.  Most of the time the ones for "parts or repair" have only minor issues which can be fixed with a few parts and knowledge available here and on the Beolover site. I would steer clear of the earlier 4000 and 4002 models as they are more difficult to bring back and have more obsolete parts.
MrLythgoe
Posts 7
MrLythgoe replied on Wed, Sep 1 2021 12:07 PM
Thank you for the advice-I will keep my eyes on eBay for one.
MrLythgoe
Posts 7
MrLythgoe replied on Sat, Sep 4 2021 10:13 AM
Hello
I have come across a beogram 4000 on Ebay.
https://www.ebay.co.uk/itm/194328766809?hash=item2d3ee5a959:g:qLAAAOSwmiNhL-L6
If you read there is problem
Judgeing by the description can anyone tell me what they suspect the issue to be and most importantly would this later come and prevent me from playing singles
Many thank Jack
chartz
Burgundy, France
Posts 4,171
chartz replied on Sat, Sep 4 2021 11:43 AM
Hi, and welcome Smile
Probably the wrong main belt or an old slippery one.
Do enquire about what was done to it when it was restored.
Jacques
MrLythgoe
Posts 7
MrLythgoe replied on Sat, Sep 4 2021 12:12 PM
Thank you for the reply.
Very glad to hear it likely to be something fairly simple.
I will do thanks.
chartz
Burgundy, France
Posts 4,171
chartz replied on Sat, Sep 4 2021 12:48 PM
Perhaps Martin (Dillen) or John (Sonavor) will say something about it too.
Jacques
Mark
San Francisco
Posts 107
Mark replied on Sat, Sep 4 2021 6:02 PM
Yes, I agree the start issue may be as simple as a servo belt. However, there also is a speed stability issue even though reported on only 45 could be more serious if it’s the motor and not simply the speed relay. This model has many mechanical elements that were improved in later series. If you are not comfortable with electronic and mechanical tech work, I would pass as you will also need to spend $200 - $800 on a cartridge.
chartz
Burgundy, France
Posts 4,171
chartz replied on Sat, Sep 4 2021 7:28 PM
Mark:
Not the servo belt, the main platter belt.
Jacques
Mark
San Francisco
Posts 107
Mark replied on Sat, Sep 4 2021 8:16 PM
Yes, that was a reference to another auction that I was going to recommend as an alternative at https://www.ebay.com/itm/284364178648 which likely needs a servo belt.
chartz
Burgundy, France
Posts 4,171
chartz replied on Sat, Sep 4 2021 9:19 PM
Too expensive for a less than perfect deck. I’d pass on that one.
Jacques
Page 1 of 1 (13 items) | RSS
