I have a Becom6000 Mk1 with two handsets. I am trying to erase the phone book and re add my new phone contacts. When I try to do this it says 'Phone book **Not Base 1**' Can anybody please help.
Ahmet
You may find it easiest to reset the base, and then the handset, and then enter the new phonebook numbers.
- Reset base: Press (dot) 7 000 8
- Reset handset: Press (dot) 7 000 9
You will then have to re-pair the handsets with the base before you can use them again.
