Just aquired a beo 9000, put discs in when I press disc button display reads correct disk but mechanism does not move, disc doesn't load, disc does not spin up a and after 30 seconds goes to what I believe is standby mode. Also radio with antenna connected only gets 1 station very staticy.
Any advice would be greatly appreciated. Thanks
Maybe your BS9000 is PIN-protected.
Check this topic: https://archivedforum2.beoworld.org/forums/t/17320.aspx
