I recently got a Beogram 4002 that I tested out before buying. I put it in Transport mode for the ride home and when I hooked it back up a couple of the buttons don't work. The Off button doesn't work and the <> button doesn't work. Everything else seems to be working fine..Any tips appreciated.
BTW, this is the model built for quadrophonic, if that matters
To confirm a few items.
1. All the buttons worked before you transported it?
2. Both the < and > buttons do not work but the << and >> do?
3. When you press either the < or > buttons while playing does the arm raise or simply continue playing?
