The simplest solution to connecting Beolab speakers to a modern non-B&O tv would be something like this:
https://www.hallaudio.com/en/
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
Mikipidia:Almando box is best
…for one BL7.1 - I’d doubt that.
Do you know the small box from HallAudio?
Hi
If your Samsung has headphone minijack out where volume is regulated via vol+/- on the remote (test it with some headphones) and a USB socket that turns on and off (maybe with a delay) I recommend this cable.
Used it for years for a BL 7.2 and a Sony TV. Worked perfectly and the BL 7.2 will turn on/off automatically.
Nothing against Steves cables.... But as far as I know he has no solution where a USB cable is providing the trigger voltage.
Your optical out is not volume regulated...
https://www.av-connection.dk/?PNo=AV-TRUSBDIN8
