I have a home made headphone lead that I wanted to use with my U70s. It’s made from Van Damme microphone cable and is long enough to sit in any place in my lounge.
i could use some sort of patch cable to connect the cable to the U70 cable, but I also wanted to display the U70s without tons of cable knocking around.
I bought a scruffy set of U70s on eBay to use as a sacrificial pair and then used mini jack sockets connected to the U70 drivers to allow the headphones to be used with any cable with mini jacks.
Will post pics when I work out how to…
Done a search on the site and whilst I can find the bit that allows you to upload photos, it says that the pics from my iPad can’t be used. I thought they’d be JPEGs ?
Any help gratefully received as it’s worth seeing the pics !
