Masterlink Troubleshooting
This post has 4 Replies | 2 Followers
SharpEars
Posts 5
SharpEars Posted: Mon, Sep 13 2021 5:09 AM
My ML network at home is as follows:
Beosound 9000 is the hub of the network and is located in the centre of the home with no speakers attached to it.
Great Room is a pair of Beolab1’s with a Beolink Eye on the wall and an active box in the wall cavity.
Kitchen has a Beolab 2000.
Study has a Beolab 3500
Ensuite has a Beolink Passive amplifier connected to some Nakamichi speakers in the ceiling and a Beolink Eye on the wall.
The system was installed around 2003 and has worked faultlessly until a kitchen renovation required changing the position of the BL2000. A ML cable had to be cut and rejoined.
The symptoms of the issue are as follows:
I am unable to switch on the 9000 using the control panel button or remote.  The unit shows a red standby light but does not light up as expected until I repower the unit.
Remoting on or using the Beolink Eye to switch on other components has no effect pre or post repowering the 9000.
About 5 minutes after repowering the 9000 and selecting radio, voila - the various speakers come to life and now the remote works with every element. Now the system works as one would expect.
Has anyone else experienced this and resolved it?
Thanks in advance.
Stoobietoo
Exeter, Devon, UK
Posts 692
Masterlink issues can often be solved by unplugging every connected unit / ML Speaker (including the active box in the wall cavity and the passive amp in ensuite.) from the mains. Plug BS9000 back in first then the other units.
Failing that, it might be the cut and rejoin is not pefect!
Stoobie
SharpEars
Posts 5
SharpEars replied on Wed, Sep 15 2021 8:59 AM
Stoobie - this seemed to work - but an hour or two later, all was just the same.
Repowering the 9000 appears to make everything right again, but it's only temporary.
Thank you just the same.
stefan
200 miles from Struer
Posts 2,920
stefan replied on Wed, Sep 15 2021 3:12 PM
SharpEars:
Usually you have no Beolabs connected to the BS9000, when there is a videomaster/Beovision. So the BS9000 resets automatically to A.OPT 0, which means, you can`control your BS9000 via Beoremote. So here you have a rare setup (you can use a Powerlink Dummy plug anyway...). But next step I'd check is, disconnect the whole system the mains again, disconnect the ML plug from the BL2000 and start the whole system (without BL2000).
Question: How did you rejoin the Masterlink cable for the BL2000? Solder or junction box?
Hope this helps
Stefan
SharpEars
Posts 5
SharpEars replied on Fri, Sep 17 2021 1:37 AM
Stefan:
• all the joins on the system are with junction boxes.
• removing the BL2000 from the network changed nothing unfortunately.
• I did however notice something new - the ML male for the BL2000 join might be dodgy. It came with the cable which I purchased second hand, so I should check that next I think.
Thank you for your input.
Page 1 of 1 (5 items) | RSS
