I'm looking into getting the Balance or the Level.
One question regarding the controle of the Balance... Can you use the Remote One BT? It's not mentioned in the specs on the B&O site. The Remote One BT is mentioned at the specs page of the Level...
Karel.
kuyttendaele:Hi, I'm looking into getting the Balance or the Level. One question regarding the controle of the Balance... Can you use the Remote One BT? It's not mentioned in the specs on the B&O site. The Remote One BT is mentioned at the specs page of the Level... Karel.
Carolpa: The app give you the opportunity to pair a BR one or the Essence Remote
OK :-) Then I can have 1 controle for the Balance or Level and the BeoVision 3 (with the BeoRemote One BT in IR mode). It's a relief that I don't have to teach my parents how to use the B&O app on a smartphone.
Hi
I asked my dealer a few months ago if there is a remote control for my Beosound Balance, the answer was still NO.
carlito:Hi I asked my dealer a few months ago if there is a remote control for my Beosound Balance, the answer was still NO.
Carolpa: carlito: Hi I asked my dealer a few months ago if there is a remote control for my Beosound Balance, the answer was still NO. Advice: go to the app and try to pair a remote. The two mentioned are shown!
Thanks for the hint - BR one and Essence listed, Halo still missing
carlito:Halo still missing
Anybody succesfully paired a Beosound Balance with a Beosound Essence Remote?
