BeoVision Haermony 65"...BeoLab 28 Anthracite....BeoLab 17 as REAR....BV10-32....BC6-26....Beosound 9000....Beosound 1 New York edt....Beogram 4002....Beoplay Emerge....Beoplay M5....Beoplay M3....Beoremote Halo....BeoRemote One BT....Beo6....Beo4....Beo4 Cinema....BeoLink 7000....Serene....H95 Black LTD....H9i Rimowa....6 x H6....Form 1....U70...
Sadly I don't have a BV8-32 so I'm only guessing with this.
Does your BV8 have the built in HDMI port or are you using a HDMI/DVI converter? Do you have access to a laptop or computer with HDMI out? if you connect a computer to it, does it recognise it as a second/external display? if you look at the display settings it should say if it detects it and might even give you some basic information on the display. This would be a good test to see if the port is picked up.
On the TV itself have you gone through the settings and selected the HDMI port to an appropriate AV source name? DVD maybe or V.Mem.
As I say just some speculative advice above, but thought it was worth trying to help you out.
Thanks,
Bristol based B&O fan with a collection including the following: BC9500, Beogram 9500, Beosystem 3, BeoVision Avant DVD 32, AV9000, Beolab 3500, Beolab 3000s, Beolab 4s, Beolab 6000s, Beovox Pentas, Beovox 3000s.
mr_anders_son: I can not get a picture with HDMI between my Beovision 8-32 and Playstation 4.
Try setting the picture quality to 720p fix using your other TV, then try BV 8-32 again.
It has 720p only and does not communicate well with the PS4...
Had the same issue with PS3 in the past.
Ralf
