Hi Guys
I have a Beovision 10-46. It has been acting strange the last 5 months....with lines across the screen. And now the screen turned black.
The TV can still turn on.
Some dealers say that the Panel is broken and needs to get changed. But it is of course very expensive.
Is this possible to do myself?
Thank you
Most likely a panel problem. Quite sure that there are no panels available for the BV10 anymore.
Better to search for a second life B10 or even better a Beovision 11.
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
It might just be the T-CON, get a third party repairer to look.
