Beocenter 1 DVD tray keep ejecting
This post has 0 Replies | 0 Followers
finite9
Posts 6
finite9 Posted: Wed, Sep 22 2021 7:23 PM
As title says, it ejects continuously even without a disc in it.  The sensor for ejecting/loading underneath the front fascia seems to work ok.  I dont know if it's dust in the drive or a sensor error.  I sprayed compressed air into it but no luck.  If it's a fault, can I just disconnect it from the circuit board or will this make other things stop working?
Regards,
Andrew
Page 1 of 1 (1 items) | RSS
DigiCert Secured Site Seal
