Cx50 Speakers (with 2 pin din connectors) on modern amp
This post has 3 Replies | 0 Followers
AdamJames
Posts 7
AdamJames Posted: Thu, Sep 23 2021 8:26 AM
Hi there,
I have picked up some Cx50 speakers that have the 2 pin Din connectors. How can use these speakers on a Technics Dx950 amp that just has the bare wire speaker connection options?
Millemissen
Flensborg, Denmark
Posts 14,680
Buy some 2 pin din connectors (ebay, amazon…..) and mount these on the speakers wire/cable with the lenght you’d need.
AdamJames
Posts 7
AdamJames replied on Thu, Sep 23 2021 8:57 AM
Thanks for the response. So the male DIN cable would just plug into something like this:
CableStop ® 2 Pin FEMALE DIN Hi-Fi Speaker Plug Cable Audio Connector PACK of 2 - Screw Connections https://www.amazon.co.uk/dp/B08DDFJRGN/ref=cm_sw_r_apan_glt_fabc_XYKX1NDP6KC71DTDCYAR
How does the speaker wire connect to the other end of this type of adapter?
Thanks again
Millemissen
Flensborg, Denmark
Posts 14,680
Exactly….since the CX50’s have a male connector.
’The other end’….I understood that the amp accepts bare wires - so just attach them (using the right terminal according to how you mounted the plug).
Page 1 of 1 (4 items) | RSS
DigiCert Secured Site Seal
