Beosound Level - selecting audio source
This post has 0 Replies | 0 Followers
Ignoto
Posts 9
Ignoto Posted: Fri, Oct 1 2021 6:08 AM
Hi everybody,
I just purchased a Beosound Level, which I intend to use for listening to CDs on an external player connected through optical cable.
I believe that the Level should automatically select the audio source when I start playing a CD, but it does not. The only way to listen to the CD source is to unplug and plug in again the audio cable. And when I use another source (radio) or turn the Level off, the CD source gets lost and I cannot find a way to select it again, expect for this unplug/plug in again manip, which is far from being ideal.
Does anyone know a way to manually select the source, because I could not find.
Thanks in advance for any feedback.
Page 1 of 1 (1 items) | RSS
