Beoplay v1 40 fiability
This post has 10 Replies | 0 Followers
olvisab
Posts 1,391
olvisab Posted: Fri, Oct 1 2021 8:38 PM
Hello
I plan to buy a v1 40 from 2012 for a guest room. Some people seem to have problem with overheating in 2020.
Could you please tell me after 8 years you are still enjoying yours ?
olivier
4 beolab 5,  beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2,  2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
Millemissen
Flensborg, Denmark
Posts 14,680
Indeed I enjoy mine/a 32”.
Not my main tv - but used for regular tv/news, a lot of YT wieving (don’t need a big screen for that mostly), radio and music listening….full 5.1 setup.
A tv that I would miss, if it was not there.
And…..I’d probably buy another one as replacement, if it had to go.
The problem, that I have heard of, is a leaking battery - mine did not suffer (yet).
If you buy one, see to that it is fully working and have that battery replaced.
olvisab
Posts 1,391
olvisab replied on Fri, Oct 1 2021 9:03 PM
Hi MM
Thanks for your answer. I don't know there was a battery inside, what is its function ?
OlivierC
Posts 128
5-year owner of a 2nd hand Beoplay V1-40 here.
Still going strong and very happy with it. Smile
Edit: it’s my main tv, daily use.
Maybe today I would consider an LG OLED tv + B&O Stage but it is also depending on the user case.
@MM, can you link or elaborate the leaking issue you are referring to?
Just in case the tv will develop the issue, owners might be able to identify the cause and possibly know what to expect for repair.
Thanks.
Olivier
Millemissen
Flensborg, Denmark
Posts 14,680
I am technical not that much into this (other forum members probably are).
From what I know it is some kind of backup batteri, that in some cases may leak and cause damage to the mainboard (which is rather expensive to replace, if possible).
And I don’t know of any specific event, that may cause this - if at all.
Every good B&O seller here (in Denmark) will replace this battery, before selling.
May it be because he will have to sell it with a warranty or just to be sure.
And I can’t say how many V1’s are infected - maybe not many??
Anyway, if I were to buy a V1, it would be something, that I would be concerned about.
In the end - buying from private will always include a risk -  these tv’s are old now/could be almost 9 years old.
As I wrote….I still love and use my V1.
The Beonic Man
Bristol
Posts 812
Hi, similar to MM here in that not only do I love and enjoy my V1-32 but if it packed in I would definitely seek to replace it with the same set if there was still one available. It’s a fantastic tv and I love the design of it. In my house, it is my kitchen tv but I do still have it on most days as I spend a lot of time in my kitchen. I have had it since 2016 and it works beautifully and perfectly every time and I’ve never experience an issue. Hope this helps. A fantastic tv with a great picture too I think. Cheers, Simon.
B&O products are V1-32, BS2, H95, E8 and an Essence remote.
11-46 now replaced with Sony A90J 65”, Sony HT-A9, Sony UBP-X800M2 and Sony SRS-NS7.
madskp
Denmark
Posts 321
madskp replied on Sat, Oct 2 2021 6:08 AM
I have one as my main TV since 2012, and until now no problems. Main source has allways been Apple TV (3 and 4).
No plans for replacing it as it is vorking just great and stable for my use
olvisab
Posts 1,391
olvisab replied on Sun, Oct 3 2021 1:51 PM
Thanks all for your answer.
I hesitate between a bv 11 46 or v1 40.
OlivierC
Posts 128
Assuming that you are considering a BV 11-46 Mk IV, the main additional features compared to the V1 are WiSA and the possibility to have a motorised stand / wall bracket.
The BV 11 has a more luxury feel than a V1 (e.g. anti-glare glass screen) but it is also a matter of personal taste and how it fits in your home interiors.
I see you own a BV 7, maybe the BV 11 is more consistent to that luxury feel.
Decisions, decisions! Smile
Olivier
lawrencejmcook
Posts 742
A BeoPlay V1 will only deliver 5.1 discrete channels of surround sound.
A Beovision 11 will deliver 7.1, because it has the full digital sound engine (V1 is slimmed down).
olvisab
Posts 1,391
olvisab replied on Tue, Oct 5 2021 3:17 PM
Hi
thanks for your answer. It doesn't need to be luxury. It is not  for my main room.
The issue with bv is that when you need to move them, it is quite heavy and you cannot do it in a hurry.
I have bought one v1. I will test it and I will see if it suits my requirements.
Page 1 of 1 (11 items) | RSS
DigiCert Secured Site Seal
