Beosystem 3 and Beovison 4-50
This post has 3 Replies | 0 Followers
Beeblebrox
Posts 4
Beeblebrox Posted: Sat, Oct 2 2021 4:25 PM
Shortly after having got my Beosystem 2 working with my beovision 4-50 I aquired a Beosystem 3.
I assumed that it would all plug in in place of the Beosystem 2, however I only have a VGA input to the Beovision, no DVI. I bought a DVI to VGA adaptor, then plunged it all up as it was with the Beosystem 2. The new Beosystem 3 appears to turn on, (a red light on it illuminates) but the beovision does not turn on. I have tried all the 9pin connectors with the same result
kallasr
Germany
Posts 2,562
kallasr replied on Sat, Oct 2 2021 6:06 PM
You do need a DVI card installed in one slot of the Beovision….
Ralf
frog
Camberley UK
Posts 624
frog replied on Sun, Oct 3 2021 11:09 PM
The issue may be that as the Panasonic screen in the beovision needs a power on command via the serial port connection, that is why it isn’t coming on. Whether you use a DVI board or VGA shouldn’t matter.
check the settings on the Beosystem 3 to ensure that you have set the correct monitor settings - it’s in the connection menu. If it isn’t set for beovision, then it won’t send the PON command to the Panasonic panel.
Beeblebrox
Posts 4
Beeblebrox replied on Sat, Nov 13 2021 11:12 PM
Hi, silly question, how do I do this with a screen that is not turning on?
Page 1 of 1 (4 items) | RSS
