Broken Beocenter 2500 Repair
This post has 6 Replies | 2 Followers
Noah
San Francisco
Posts 71
Noah Posted: Sat, Oct 9 2021 1:16 AM
Hello. I put a new tape belt in my BeoCenter 2500. Now it wont power up.
https://www.youtube.com/watch?v=yJ9J21HBNZo
-Noah M.
RL 60.2, Beogram 5500, Beomaster 5500, Master Control Pannel 5500, Audio Terminal Remote, H9i, Beovox s45.2, Beosystem 2500 , Beogram 1602, Beolink 1000 remote, Beosound 2000, Beoremote 4.
Looking for: Beocenter 8000
Tom_M
Posts 6
Silver Member
Tom_M replied on Sat, Oct 9 2021 5:48 PM
Wow, fair bit of corned ham on here, these days: seeing as this thread can't get much worse, I'll take the chance to chip in with my zero-post account. I am real, though.
It really sounds like something isn't plugged in, despite your saying it all is. I'd start with making sure the ground and all the plugs on the front panel are connected, including the two which are identical but for the red paint – that one goes at the top.
If that doesn't work, follow those plugs to the other end – i.e to the µP tin – and make sure they're plugged in, as well. As you have to go in the back for that, it's also a chance to check the fuses and voltages, and go from there.
Noah
San Francisco
Posts 71
Noah replied on Mon, Oct 11 2021 6:23 AM
Hello. Thank you for your response. Please see this video I made with the ground connection that I think is the issue.
https://www.youtube.com/watch?v=IHddzuugOJY
Thank you so much.
Noah
-Noah M.
Noah
San Francisco
Posts 71
Noah replied on Mon, Oct 11 2021 6:24 AM
Hello. Here is a video of the ground wire I think is the issue. Where would it connect?
-Noah M.
Guy
Warwickshire
Posts 2,590
Guy replied on Mon, Oct 11 2021 9:13 AM
Noah:
That attaches under the second screw from the right in the STEP 2 photo here: https://archivedforum2.beoworld.org/forums/p/4707/42777.aspx
You can also see it loose in the STEP 4 photo.
Noah
San Francisco
Posts 71
Noah replied on Mon, Oct 11 2021 6:20 PM
Thanks! I will try this later today.
-Noah M.
Guy
Warwickshire
Posts 2,590
Guy replied on Mon, Oct 11 2021 6:41 PM
Noah:
Just make sure that the connecter is placed between the screwhead and the metal chassis, rather than between the metal chassis and the plastic threaded part.
Page 1 of 1 (7 items) | RSS
DigiCert Secured Site Seal
