Smoking Beomaster 5
Macattack1
Posts 9
Macattack1 Posted: Sun, Oct 10 2021 6:17 AM
hi guys , I’m hoping someone can help with an issue I just experienced with my Beomaster 5. I hadn’t used it for a while and plugged it in. After about 30 seconds it started making a terrible noise and I quickly turned it off at the power point. It started smoking and smelling really bad . I opened it up and found something on the mother board had failed . I think it may have been a fuse but not sure. I’m not really sure watt to do but thought someone might be able to help me.
laseralex
Posts 240
laseralex replied on Mon, Oct 11 2021 1:31 AM
My first thought is a failed capacitor.  I recommend reposting your request on The Workbench forum, including a couple of photos of the failed component.
https://archivedforum2.beoworld.org/forums/26.aspx
Sources: 2x Beosound Moment • 4x Beosound Essence Mk II
Speakers: 3x Beolab 8000 • 2x Beolab 6000 • 2x Beolab 3 • 3x Beolab 2
Integrated:  1x Beosound 2 • 1x Beosound Level • 4x BeoPlay M5 • 1x BeoPlay A6
Control:  16x* Essence Remote  • 1x Beoremote Halo
* Yes, really! 🤦‍♂️
Macattack1
Posts 9
Okay thank you.
Its a small light brown rectangular glass box which exploded. Where would I find the The Workbench forum?
Page 1 of 1 (3 items) | RSS
