Essence MkII white/green LED flashing after update
This post has 12 Replies | 1 Follower
stereomann
Posts 32
stereomann Posted: Sun, Oct 10 2021 7:41 PM
I'm hoping to find support. I just bought a BS Essence MkII, set it up and found out that a firmware update has been available. I ran the update  with the use of the B&O App until it stated that the firmware has been finished. After that the app was unable to find the Essence and I decided to power it off completley by pulling the mains off. Now it won't start at all and only the green and white LEDs are flashing slowly all the time. No chance to setup the Essence again, neither to access via browser...
Any assistance or thought is highly appreciated
Thanks, Alex
Bw789
Posts 74
Bw789 replied on Sun, Oct 10 2021 10:41 PM
Hey Alex,
are you able to log into your home router to see if it has an IP address?
Bw789
Posts 74
Bw789 replied on Sun, Oct 10 2021 10:42 PM
Also have you tried a factory reset?
stereomann
Posts 32
stereomann replied on Sun, Oct 10 2021 10:48 PM
Thanks for sharing your ideas !!
I tried both. The Essence's IP adress isn't visible as it seems to me that the unit doesn't even start. And so it's with a Reset...which I tried several times. But as the manual says, resetting the Essence is only possible if the green LED is ON ...and not flashing.
Alex
stereomann
Posts 32
stereomann replied on Sun, Oct 10 2021 11:10 PM
I fear that the Essence has somehow being bricked Sad
stereomann
Posts 32
Bw789
Posts 74
Bw789 replied on Mon, Oct 11 2021 9:42 PM
Have you got the Essence plugged in via Ethernet? if so, can you try another cable or test your cable to make sure it works? the manual states the essence cannot be reset unless it has a network connection.
stereomann
Posts 32
stereomann replied on Mon, Oct 11 2021 10:10 PM
I immediately tried this. Took another cable and plugged the Essence to the mains. 20 minutes are gone and sadly there’s no change to the flashing LEDs. To me it seems that something went wrong during the update process or when I pulled the plug for trying a restart.
stereomann
Posts 32
stereomann replied on Mon, Oct 11 2021 10:15 PM
I searched the web for finding some other way to reset the Essence completely, eventually a buttons sequence that could be used or something similar. But with no luck. Perhaps it’s time to contact a dealer or service station. Or to keep everything as it is…with an AirPort Express attached to the good old BM7000 :-)
stereomann
Posts 32
Just sharing how my Essence drama continued/ended:
After not having used it for nearly 2 weeks I decided to check the Essence again, connected to the mains, green/white LEDs flashing... no miracle happened.
I called a local B&o dealer, told my story and asked if the Essence can be checked/repaired.
In a very polite way he explained that there's no chance of repairing this unit anymore as it's an outdated product where no further support is given and no parts are available any longer. If I'd like to come around he could trying a reset (which was done 100 times ;-) ...and in the meantime I could have a deeper look at the S8 or the Beosound Core ;-)
It's somehow sad that the Essence is dead. On the other hand this experience showed that the good old B&o components are still worth being in use.
After fiddling around with some (non B&O) Airplay speakers it turned out that:
first: sound quality wasn't by far not as good as with the Beovox/Beolabs  installed in nearly each room of the house
second: choosing the correct airplay speaker, telling Siri to continue playing music on that specific speaker or room in addition to other speakers, etc. was too complicate, not reliable and without the slightest chance of getting any WAF :-)
At the end of the day I decided to do the following:
One audio source only (Apple TV - HDMI audio extractor)
Keeping all MCL linked rooms, feeded by the use of a 1611 converter box and a Beolink ML/MCL.
Turning the "main room" into a "link room" as well because this gives independent volume control and access to local sources in the living room.
Everywhere in the house music is now simply turned on by pressing "TV" on Beo4, then telling Siri to play music, radio, podcasts on Apple TV (or "air-playing" content from an i-device to Apple TV)
It's so "clean", logical, convenient and comfortable..and to me still the one and only real multiroom system (in the Beolink understanding of multiroom).
Happy with this solution ..and the Essence is nearly forgotten
Alex
Guy
Warwickshire
Posts 2,590
Guy replied on Fri, Oct 29 2021 12:05 PM
^ Good to hear that MCL is working well!  My current house (provisionally sold but I've not yet moved out) has an MCL system, fed also by an Airport Express, and it is all still working very well!  Once I have moved I am debating staying with MCL or moving to a much more modern ML system Smile.
stereomann
Posts 32
A hard decision that needs to be done, Guy :-)
My (very little!) experience with ML is by far not as good as with MCL..these multiple, tiny cables, connectors with plastic noses, etc. ;-) Of course ML offers more flexibility...but I'm still happy with the MCL system ...installed behind bricks and mortar.Wink
Just an idea: Why not thinking of NetLink? I've had a NL equipped Beoplay V1 TV once, connected to a ML/NL converter and via a 1611 to my MCL-Beosystem. It has been great fun to control a Beogram 8002 record player via App, listening to FM-radio with the Beoplay's speakers, V1's SAT-radio to the Beosystem connected speakers, etc.
But at the end of the day I came to the conclusion that it has been some sort of "overkill". Plus: all these AC powered devices in stand-by mode that have been in use mostly only every now and then...
I came to the conclusion that a simple but very robust system, most rooms are equipped with passive x-tra speakers kits (only two rooms, living room and music room, have independent volume control, local sources, etc).
From that point of view I'd advise to keeping the MCL system....
...hard decision that needs being done ;-)
Cheers,
Alex
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Fri, Oct 29 2021 4:10 PM
Guy:
ML is also past. If you move, move to NL.
Page 1 of 1 (13 items) | RSS
