Smoking Beomaster 5 - possible capacitor
This post has 7 Replies | 0 Followers
Macattack1
Posts 9
Macattack1 Posted: Mon, Oct 11 2021 4:28 AM
hi guys , I’m hoping someone can help with an issue I just experienced with my Beomaster 5. I hadn’t used it for a while and plugged it in. After about 30 seconds it started making a terrible noise and I quickly turned it off at the power point. It started smoking and smelling really bad . I opened it up and found something on the mother board had failed . I think it may have been a fuse but not sure. I’m not really sure watt to do but thought someone might be able to help me.
laseralex
Posts 240
laseralex replied on Mon, Oct 11 2021 8:33 AM
Do you have a photo of the failed component?
Also, do you know how to solder replacement components if we can determine the correct replacement part?
Sources: 2x Beosound Moment • 4x Beosound Essence Mk II
Speakers: 3x Beolab 8000 • 2x Beolab 6000 • 2x Beolab 3 • 3x Beolab 2
Integrated:  1x Beosound 2 • 1x Beosound Level • 4x BeoPlay M5 • 1x BeoPlay A6
Control:  16x* Essence Remote  • 1x Beoremote Halo
* Yes, really! 🤦‍♂️
Macattack1
Posts 9
Yes I do have a photo and I think I could solder if we found the failed component.
Macattack1
Posts 9
Macattack1 replied on Mon, Oct 11 2021 11:28 PM
Hi Laseralex
thank you for your reply. Did you see the photo I posted of the item that exploded?
laseralex
Posts 240
laseralex replied on Tue, Oct 12 2021 12:47 AM
Macattack1:
No, I don't see any photos in any of your posts.
* Yes, really! 🤦‍♂️
marexy
Posts 710
marexy replied on Tue, Oct 12 2021 6:32 PM
May be many things...you can send me PM with photo.
Macattack1
Posts 9
Macattack1 replied on Wed, Oct 20 2021 11:31 AM
Macattack1
Posts 9
Macattack1 replied on Wed, Oct 20 2021 11:32 AM
How do I send a photo ?
Page 1 of 1 (8 items) | RSS
