Beo6 and Sky Q
This post has 1 Reply | 2 Followers
bdm01
Posts 29
bdm01 Posted: Tue, Oct 12 2021 11:12 AM
Hope someone can advise / help
Have a Beo6 and the config tool and have used for a long time to program things up
Always worked great
Just upgraded from the old Sky HD box to Sky Q
Anyone programmed the Beo6 to send commands to Sky Q ?
Do you still need to use the little IR bud to control ?
What stating config did you use and edit to replicate the commands ?
The Sky Q doesn't appear in my config tool settings anywhere
Hope someone can give me some pointers
Regards
Stoobietoo
Exeter, Devon, UK
Posts 692
Is Sky Q controlled by IR or Bluetooth? Unless it is IR the Beo6 cannot control it.
Stoobie
Page 1 of 1 (2 items) | RSS
