Help with Beolink Converter NL/ML
BeoJosh
Posts 89
BeoJosh Posted: Tue, Oct 12 2021 3:06 PM
I just installed a pristine and fully serviced MK3 Beosound 9000 and am trying to connect it into my new B&O ecosystem with a Beolink Converter NL/ML that I bought on eBay. The 9000 is connected to the BLC via masterlink and is set to A. Opt 0, and the BLC is connected via ethernet to my network.
I've been able to add the BLC into my B&O app, but that's about it. The 9000 operates fine (though the IR is locked out), but the BLC is not functioning as intended--it doesn't seem to recognize that music is playing, and there is no app control in the B&O app, or a tab for setting app control in the web interface of the BLC. I can't join any systems to the BLC since it doesn't think any music is playing, so I have no sound.
Through the web interface of the BLC I can see it's running SW version 1.3, and SW version 1.4.3.19864 is available. However, every time I try to download the new software through the BLC web interface, it immediately says Download Failed.
Any advice for how to update the BLC software, and for which settings I should use in the BLC to get things working? I'd really love to listen to my new (old) Beosound 9000. Thanks in advance....
Beovision Harmony 77, Beovision Harmony 65 x2, Beovision Contour 48, LG GX 65/Beosound Stage/STB Stand
Beolab 50s, Beolab 28s, Beolab 18s x3, Beolab 19, Beoplay A9, Beosound Edge, Beosound 2 x2, Beosound 1 x2, Beosound Level x2, Beosound Core x2, Beoplay M3, Beosound 9000, Beogram TX2, Beogram 6500 White Edition, 4000c (on order), Beoremote One x8, Beoremote Halo x3, BLC NL/ML
Beoplay H95 x3, Beoplay EQ x2, Beoplay E8, Beoplay E8 Sport, Beosound A1 x2
beojeff
USA
Posts 2,012
beojeff replied on Wed, Oct 13 2021 11:10 AM
Control of devices through an NL/ML Converter is not very good through the B&O app. I don't see why it's so difficult for B&O to get the app to properly control the device with datalink in the app, but they haven't seemed to give it much attention.
However, if you have the converter set to Video Master and have the sources ticked on the configuration, you can easily add those sources of the 9000 to be included in the local source list of your NL products.You need to add the converter as a primary or secondary linked device to your NL device. Then, you just select the 9000 source such as CD using your beoremote on the NL device.
BeoJosh
Posts 89
BeoJosh replied on Wed, Oct 13 2021 2:26 PM
Thanks @beojeff. I tried this, but sadly, it still wouldn't work. I'm arranging to return the Beolink Converter and get a new one, as I really think it's an issue with this particular unit. Will report back once the new one arrives. Appreciate the advice!
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Wed, Oct 13 2021 6:25 PM
BeoJosh:
This is the reason the BLC doesn't work properly.
Contact B&o for the update. After the update and the settings Beojeff proposed it should work.
Note: I would set the BLC as ASlave in your setup (both should work though)
BeoJosh
Posts 89
BeoJosh replied on Wed, Oct 13 2021 6:58 PM
Thanks so much. I've already returned the BLC but will do this with the new one if it doesn't have the latest sw installed.
Related question: Is the aux input on the BLC also distributable? Just wondering if I can ditch a Core I have for a turntable in the same room and repurpose it elsewhere.
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Thu, Oct 14 2021 4:55 AM
BeoJosh:
-- Beovision Harmony 77, Beovision Harmony 65 x2, Beovision Contour 48, LG GX 65/Beosound Stage/STB Stand Beolab 50s, Beolab 28s, Beolab 18s x3, Beolab 19, Beoplay A9, Beosound Edge, Beosound 2 x2, Beosound 1 x2, Beosound Core x2, Beoplay M3 Beogram 4002, Beogram TX2, Beogram 4000c (on order) Beoremote One x7, Beoremote Halo x3 Beoplay H95 x3, Beoplay E8, Beoplay E8 Sport, Beosound A1 x2
the line-in of the BLC can be distributed.
My BS5e is BLC connected and is a source in my Shape.
BeoJosh
Posts 89
BeoJosh replied on Thu, Oct 14 2021 3:40 PM
Thanks, @carolpa. Appreciate it. Good to know. It'll help simplify things, and I have some plans for that Core elsewhere!
Page 1 of 1 (7 items) | RSS
