Beosound Core optical output broken after SW-update?
This post has 6 Replies | 0 Followers
jkjaer
Posts 6
jkjaer Posted: Fri, Oct 15 2021 8:08 PM
Today (October 15) at 1.25 CET, my Beosound Core was updated to SW-version 1.12.47108.120390320. Unfortunately, this update seems to have broken the optical audio output as my Beolab 20 speakers no longer plays any sound. They only turn on when I try to play something.
I have tried different sources and nothing works. Restarting the Core also has no effect. I have also tried to reboot the speakers and switch them around, but it makes no difference.
Has anyone else this problem? Is it possible to revert the SW-version of the Core back to the previous version?
mhslarsen
Posts 4
mhslarsen replied on Fri, Oct 15 2021 8:16 PM
Hi
I have seen the same behavior with Core and my BL50/BL20 connected via Toslink - as a work around you can downgrade to “48 kHz” from “96 kHz” in the “optical-out” setting menu in BS Core. I have been in contact via B&O today, but it’s not possible to revert to the previous version …
Razlaw
Posts 4,345
Razlaw replied on Fri, Oct 15 2021 8:18 PM
Glad to see this thread. I do not yet have that version so have now turned off automatic updates.
jkjaer
Posts 6
jkjaer replied on Fri, Oct 15 2021 9:09 PM
Thanks a lot for the quick reply. I can confirm that lowering the sample rate to 48 kHz works.
jkjaer
Posts 6
jkjaer replied on Wed, Oct 27 2021 5:41 AM
My Core was updated with a new SW-version yesterday, and this seems to have fixed the issue.
Beofile7
Posts 150
Beofile7 replied on Wed, Oct 27 2021 6:25 AM
Fixed mine yesterday with update. Interestingly it did not auto update. I had to manually do it.
pig30n
Posts 35
pig30n replied on Mon, Nov 1 2021 3:49 PM
Beosound Core software update 1.12.47460 popped today in the app.
Is it safe to upgrade ?
Thanks!
Page 1 of 1 (7 items) | RSS
