Beocentre 9300 headphone socket
This post has 4 Replies | 0 Followers
Holty
Posts 17
Holty Posted: Sat, Oct 16 2021 2:24 PM
Hi all. My headphone socket has stopped working 🤔. It was working fine then next time I tried nothing. I’ve found a second hand headphone socket with wiring for sale but want to know how to remove old one. The little panel around it looks like it should remove but I don’t want to force it. Any help would be greatly appreciated as I only use the system with headphones. The sound does come through the headphones but the speakers don’t mute. Thanks in advance. Steve
lawrencejmcook
Posts 742
Holty:
Sorry - my first reply did not appear.
Do you have passive speakers?
If so, and if they are connected to the Speakers 2 socket, then plugging in headphones will not mute them.
Connect the passive speakers instead to the Speakers 1 socket. Connecting headphones should now mute them.
lawrencejmcook
Posts 742
Holty:
Holty
Posts 17
Holty replied on Thu, Oct 21 2021 4:24 PM
Thanks Lawrence. Yes I have passive speakers but these don’t work when you plug  them into the active speaker sockets. Thanks, Steve
lawrencejmcook
Posts 742
Holty:
Hi Steve,
Do not connect your passive speakers to the Powerlink (active) speaker sockets. These have 8 holes in the socket.
Connect them to the Speakers 1 (amplified) sockets. These should only have 4 holes in the socket and are clearly labelled. Look carefully for the diagram and legend on the back of the BC9300.
They are the ones labelled “passive speakers - right - left” near the top of page 5 of this manual:
http://www.iconic-av.co.uk/manuals/Beocenter_9300-Owners_Manual.pdf
Lawrence
Page 1 of 1 (5 items) | RSS
