Hi all, Just turned on my Beosound Mark2 for the first time in ages, and there is no sound.The power lights on Speakers and Base woofer all light up green, the disc spins and the cds change flawlessly. Just no sound at all. All the wires are connected properly.Pressed the "Mute" button on the beosund 9000 keypad to see if its sticky...no joy, still no sound even though the display shows the sound level rising/falling!When I press the radio button, there is sound out of all 3 speakers. Static because radio not connected, but the sound works.As soon as I revert to CD, the disk turns but no sound at all.Turn it off, unplug it - return, get sound on CD for a few seconds then cuts out.Any ideas?Thanks
