I recently acquired a Beogram 8002. I'm told it worked when it was last used, but that may have been some time ago. The turntable spins and the button panel seems otherwise functional as far as I can tell. The tonearm does not move.
I could use a little guidance here. I am an audio tech, but this turntable is very foreign to me.
I suggest you download the service manual at for instance, Beogram 8002, as opening up the table is not intuitive. Your problem may be a simple as the need to replace the servo belt; however, I would start with the manual.
This post shows how to open a Beogram 8000/8002 into the service position.There are examples of working on the Beogram 8000/8002 here.
Be careful when opening the turntable to its service position. It is easy to damage the tonearm and the dust cover.
-sonavor
