For any Beogram 4500 owners out there, could you tell me the clearance height (from the tabletop/surface to the front bottom edge of the turntable) of the front lip of the turntable? Looking to possibly add another Beogram that would live on a pull-out shelf, and want to make sure it'll fit. Given the height of the shelf handle, I think the design of the 4500 might be my best option. Thanks!
--Beovision Harmony 77, Beovision Harmony 65 x2, Beovision Contour 48, LG GX 65/Beosound Stage/STB StandBeolab 50s, Beolab 28s, Beolab 18s x3, Beolab 19, Beoplay A9, Beosound Edge, Beosound 2 x2, Beosound 1 x2, Beosound Level x2, Beosound Core x2, Beoplay M3, Beosound 9000, Beogram TX2, Beogram 6500 White Edition, 4000c (on order), Beoremote One x8, Beoremote Halo x3, BLC NL/MLBeoplay H95 x3, Beoplay EQ x2, Beoplay E8, Beoplay E8 Sport, Beosound A1 x2
Thanks so much! That’d work perfectly.
