ABR unit Beovox Red line RL60
Carolpa
Posts 1,700
Silver Member
Carolpa Posted: Mon, Oct 25 2021 3:43 PM
Just opened a Beovox RL60 and found the metal plate loose in the speaker (second picture). I presume it is part of the  ABR unit. Correct?
second presumption: the plate was glued to its frame with a kind of membrane. But this material has complete gone. Can I use a EPDM rubber? Or what was the membrane original made of?
Johan
Bolsward, NL
Posts 450
Johan replied on Mon, Oct 25 2021 6:37 PM
Hi Carolpa,
Somewhere in this thread https://archivedarchivedforum2.beoworld.org/forums/t/20420.aspx Steve lists the options. I trust the B&O tuned port kits will not be available anymore, so maybe Dillen (have not seen him around on the forum for a while) can fix your ABRs?
I also read about neoprene as a material, but that is said to be hard to glue. I trust that the density/weight of the material plays an important role in the vibration behaviour?
Regards,
Johan
Johan
Bolsward, NL
Posts 450
Johan replied on Mon, Oct 25 2021 8:56 PM
And the elasticity of course. There are suppliers that sell various thicknesses of EPDM and Neoprene sheets (even self-adhesive) at reasonable prices, so a bit of experimenting could also be an option.
Page 1 of 1 (3 items) | RSS
