Beolab 3 problems
Omid Moshtagh
Burlington Ontario Canada
Posts 50
Omid Moshtagh Posted: Sun, Oct 31 2021 7:05 PM
Hello Beoworld,
I have a Beolab 3 which is not functioning as per my other ones. It turns on and off the same as the other ones, but only sound from the tweeter. Then if I turn the volume up at a certain point the speaker kicks in and starts to play like the other ones, and you can feel the vibration on the speakers.
If I turn the volume down there is a static sound on it...until it goes back to the way it was meaning only sound from tweeter, until i turn the volume up for it to kick in....
Any ideas?
Thank you,
Esax
Posts 323
Esax replied on Sun, Oct 31 2021 7:35 PM
Do you have a powerlink splitter?
Beovision 7-55 MK1 red, Beolab 10 red. Beolab 50, all black. Beolab 17 broken ice. Beolab transmitter. Apple tv4 and apple express 2.
Omid Moshtagh
Posts 50
I've tried different connections and the behavior is the same, so at the moment its set to line in and is connected via 3.5mm to an audio out.
But before I had single power link connected to a beosound 4 and directly to the beolab 3 and the behavior was the same...
Beouser66
Posts 47
Beouser66 replied on Sun, Oct 31 2021 8:44 PM
i think you have to get it repaired, probebly icepower module faulty
Page 1 of 1 (4 items) | RSS
