Can I replace the Room ML with WiFi
SteveieK
Posts 12
SteveieK Posted: Mon, Nov 1 2021 12:02 PM
I have B&O Sound 5 system and have ML cable between it and a Beolab 3500 plus another speaker in the kitchen and wondered if I can replace the ML with wifi connections to the Beo sound 5?
Millemissen
Flensborg, Denmark
Posts 14,680
SteveieK:
No!
That said - there was a product, that could make this connection wireless:
https://www.beoworld.org/prod_details.asp?pid=1028
However, not many would recommend this product - it was a hit and miss, whether that worked flawless or not.
In any case, a cabled connection is allways the best - especially it it already is there Smile
SteveieK
Posts 12
Thanks MM, I’ll stick with ML cable connection just need to replace the outside junction boxes again!
beojeff
USA
Posts 2,012
beojeff replied on Tue, Nov 2 2021 6:38 PM
There actually IS a way to join your ML devices to your wifi network. That would be by converting them to NL via NL/ML Converters connected to each ML device. The converters would then need to be connected by CAT7 to a wifi access point. This is a rather costly investment, but it brings your ML devices into a more modern B&O network with robust connections and the ability to add Deezer and TuneIn just by adding any NL device to your network.
Page 1 of 1 (4 items) | RSS
