Today, somebody had thrown out a beautiful Beolit 700 in the trash and I picked it up and checked that it worked. Seemingly it did - there was static. So far so good. However, I was not able to tune any radio stations, so I opened it up, and what I found was that a small plastic tab had broken on the tuning slider. Is there a way to take it out so I can glue it properly, or do I need to be really steady if it can't be taken out?
I also found a piece of plastic that I have no idea where belongs. It was rattling inside the radio. Where does it go?
Apart from that, only a slider button for the tone (bass/treble) seems to be missing.
Any help is appreciated.
/Filip
Dear Filip,
Beolit sliders are very hard to find.
There is thread about slider 3D print https://archivedforum2.beoworld.org/forums/p/43602/316018.aspx#316018
Try to ask member Dillen on this forum, he can supply pretty much vintage parts.
