MCP 5500 Micro switch
This post has 3 Replies | 0 Followers
nicksmith2010
Posts 2
nicksmith2010 Posted: Thu, Nov 4 2021 11:04 AM
After a few hours searching I seem to have drawn a blank. Does anyone know where I might get hold of a microswitch for the volume dial on a MCP5500. Also are there any drawer belts out there for beocord 5500 type 4932.
Thanks in advance
Homersaurus
Posts 28
I'm not sure there is a microswitch for the volume dial; I thought there was a circular wheel with black and white markings and an optical reader for the wheel - i.e. no mechanical connection or potentiometer.  The opto reader for the MCP 5500 wheel and suitable drawer belts for a Beocord are available on www.beoparts-shop.com.
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Fri, Jan 7 2022 6:29 PM
There is an opto reader and a switch.
Basically, you can say that the switch tells the direction of the wheel and the opto component counts the black/white pulses.
Beoparts-shop can do do a lot more than what meets the eye. Some times it's a good idea to just ask.
ProGram
59269 Beckum, Germany
Posts 383
ProGram replied on Mon, Jan 10 2022 11:19 AM
Take one of those micro switches and discard the spring blade https://wirsindspiele.de/de/automaten/Musikboxen/ersatzteile-musikbox/nsm/mikroschalter-umblaettertaste.html
Page 1 of 1 (4 items) | RSS
