Beolab 12-3 and Essence mkII odd noise when changing volume
j_lowry
Posts 18
j_lowry Posted: Fri, Nov 5 2021 7:17 PM
Strange noise issue
When changing the volume level using airplay on the Beosound Essence there is a brief buzzing sound on the Beolabs. Ive tried a different Essence and it does the same thing. If I unplug the powerlink cables on the back of the essence and replug them back in then the noise issue goes away but comes back eventually. I'm using cat6 cables if that makes a difference
Otherwise they play music just fine. Any ideas?
lawrencejmcook
Posts 742
I think that the minimum standard for RJ45 cables is CAT 7 (the shields run plug to plug).
Have you tried using either CAT 7 or B&O official RJ45 Powerlink cables?
Mikipidia
Posts 2,169
Its a bad ground in the wire, had that too before. Doesn’t do any damage. But the seating on the back of the speakers may be a little loose, or on the essense.
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
Page 1 of 1 (3 items) | RSS
