Hello,
I am in need of a set of better speakers, I currently use a roksan radius 5 with the clear plinth and i believe a set of beovox 2500 cube tweeters would look brilliant with my turntable.
Obviously the beovox 2500 cubes are only tweeters so what i would like to know is how could i get this to work without buying the beovox 5000 system and making it work fairly cheaply.
One suggestion i have thought about is i have some old technics speakers however they have bad tweeters and i would be able to take a lead from the tweeters and send them to the beovox 2500, so would this work?
Could i simply just take a feed straight from my amplifier to to the beovox 2500
Many thanks Jack
Hi Jack,
No, you can’t. It’s that simple. They don’t produce anything else than treble.
Jacques
