Beogram 6500 master control panel reset using a beo 4 controller?
This post has 12 Replies | 2 Followers
Nick293
Posts 4
Nick293 Posted: Tue, Feb 26 2013 10:15 AM
Hello
i have inherited a beogram 6500 system, with Penta speakers. Tape, cd and amp.
I also have the master control panel.
its worked in the past but following the power being disconnected its not working, remote says "no contact"
In the past I used my in-laws beo 4 controller and successfully reset it, so that I could use the master control panel again. I can't remember how I did It!!!
Tried googling this but never quite get the right info.
Any help would be most appreciated. The systems a lovely big ornament at the moment...
nick.
chartz
Burgundy, France
Posts 4,171
chartz replied on Tue, Feb 26 2013 4:18 PM
It could be several things, or their combination.
There could be a bad capacitor inside the Beomaster, on the IR PCB.
Same thing inside the MCP.
Also, the MCP and Beomaster IR windows can become dirty inside!
Jacques
tournedos
Finland
Posts 7,357
tournedos replied on Tue, Feb 26 2013 5:04 PM
Simple things first... the Beomaster has possibly forgot its option setting.
To reprogram it to the correct option setting (A.OPT 1) with a Beo4:
  1. Ensure the Beomaster is on standby
  2. On the Beo4, press standby (the red dot) and LIST at the same time -> display shows OPTION?
  3. Press GO
  4. Press LIST until display shows A.OPT
  5. Press 1
  6. Confirm that the Beomaster displays briefly °1
Now the remotes will hopefully work again.
Of course, the Beomaster should keep this setting over a power interruption. The backup battery is probably dead, but replacing it will be a lot more difficult than the steps above.
(This is going the be the last time EVER I will rewrite these instructions on this forum... Big Smile )
--mika
Nick293
Posts 4
Nick293 replied on Thu, Feb 28 2013 7:59 AM
That worked!!!!
thanks a bunch!
tournedos
Finland
Posts 7,357
tournedos replied on Thu, Feb 28 2013 8:04 AM
Very good, enjoy Smile
--mika
ouverture
London
Posts 263
ouverture replied on Tue, Mar 26 2013 2:25 PM
tournedos:
Ensure the Beomaster is on standby On the Beo4, press standby (the red dot) and LIST at the same time -> display shows OPTION? Press GO Press LIST until display shows A.OPT Press 1 Confirm that the Beomaster displays briefly °1 Now the remotes will hopefully work again.
(This is going the be the last time EVER I will rewrite these instructions on this forum... )
--mika
Hi Mika,
does that neat trick with a Beo4 also work for the 5500 BM as well ?
Peter
Earsdon
Posts 11,991
Peter replied on Tue, Mar 26 2013 2:40 PM
Yes - or do what most B&O engineers do and keep a Beolink 1000 spare - Sound 1 Store. Much easier!!
Peter
ouverture
London
Posts 263
ouverture replied on Tue, Mar 26 2013 7:30 PM
yes, I sort of remember now, and if the audio (5500) was in one room, and the video in another, then use on the BL1000 remote Sound 2 Store
simples - thanks Peter for jogging my brain cells :-)
tournedos
Finland
Posts 7,357
tournedos replied on Tue, Mar 26 2013 7:43 PM
For completeness, another tip:
if you don't have a B&O TV in the same setup, you might consider using option 2 instead of 1. Then you can conveniently switch the Beomaster to AUX with the TV button on the remote (MCPs have a direct AUX button, but most of the other remotes don't). Very logical to use if you happen to have a 3rd party TV set connected to the AUX for better sound through the B&O audio.
--mika
sdahmer
Posts 1
sdahmer replied on Thu, Dec 21 2017 1:37 AM
Thanks You so much! This worked for me too! I was going to send all 4 components back for service, but this fixed the problem.
Best ever!
lausvi
Helsinki - Finland
Posts 689
lausvi replied on Thu, Dec 21 2017 2:36 PM
tournedos:
Nice, thanks for this Yes - thumbs up
gummiie
Posts 1
gummiie replied on Sun, Jun 9 2019 4:42 PM
Hi
I followed your instruction with Beomaster confirmed and displayed °1, however, MCP 6500 still show "No Contact".  Could this be some parts are broken?  Is there an alternative to your instruction stated here?
Thank you,
KC
tournedos
Finland
Posts 7,357
Once the Beomaster has acknowledged the setting update just as you saw, the configuration is OK and things should just work.
If it still doesn't, it could be a problem either in the MCP or the Beomaster. I believe it is safe to say that all BM6500s will be ripe for capacitor overhaul by now, and the MCPs can fail similarly as well.
--mika
Page 1 of 1 (13 items) | RSS
