Is there a trick to getting the Beoplay A8 to appear in the B&O app? My BPA8 is connected to my 2.4 GHz Wi-Fi network: I can Airplay to it all day & night. Via a web browser, I can access its internal web server; it says the software is up-to-date. However, I can’t ‘see’ the device in the B&O app.
When I select the generic BPA8 from the ‘add a device’ section, the app looks for my device on the network, can’t find it, tells me to look for the hotspot network with the device name, which in turn never appears in my list of available networks. Game, set, and match. Frustrating.
Any ideas? And thanks.
Thanks for the quick reply. I initially set the unit up per B&O’s included instructions, which if memory serves involved cabling the unit via Ethernet to my router. That was about 5 or 6 years ago, so I’m vague on the details. In any event, I just went through a similar setup again, resetting the network connection, to see if that would allow the device to be seen by the App. I used your instructions (thanks twice). That worked as expected — the unit is up and running on the network, but didn’t resolve the App issue.
