BEOlink Passive - no lights nor buttons working
SuffolkSimon
Posts 3
SuffolkSimon Posted: Sun, Nov 21 2021 9:52 AM
I’ve got a BEOLink Passive. The IR/Eye will work with the remote control but there are no lights on it and the buttons don’t work.  Any clues/ideas please?
Guy
Warwickshire
Posts 2,590
Guy replied on Sun, Nov 21 2021 10:45 AM
Check that the IR eye's DIN plug is firmly pushed in to the Passive (remove and replace)
Check the connections inside the IR eye, particularly the Yellow and Grey wires.
Check the connections inside the DIN plug, same wires.
SuffolkSimon
Posts 3
Thank you very much. I checked them all then checked the wiring diagram I’d been given. It turns out that what I’d been given was wrong (2 and 5 had to be swapped).
All working now.
Thanks again.
Guy
Warwickshire
Posts 2,590
Guy replied on Sun, Nov 21 2021 9:06 PM
Great news - glad you got it working!
Page 1 of 1 (4 items) | RSS
